19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Inquire about Duplication of Levels in Revit
Hi all
I have a problem which relate with the duplication of levels in Revit
When I duplicate the level , and then going to elevation ( assuming North Elevation )
I don't find the level that I duplicated.
how can I overcome this problem ?
Thanks alot
How do you think you are duplicating a level? Duplicating a plan does not create a level.
so what the difference between duplicating the plan and creating a new level
The duplicating level works as the main level that has been duplicated but is not viewable in elevation views (It is only a duplicated view not another level).
You can learn how to create a new level here.
IIf you want the same elements on by levels, you can copy to clipboard from one level and use paste aligned to selected levels, This is explained here.
Thanks alot
Duplication of details on different sheets |
Fri, Nov 9, 2007 at 11:59:50 AM
Cannot see my floor levels |
Tue, Mar 10, 2015 at 12:42:26 PM
Window Mark Duplication Warning |
Tue, Apr 6, 2010 at 10:47:54 AM
duplicate at a different level |
Thu, Jun 12, 2008 at 8:16:35 AM
Replacing levels with ref planes or deleting excess levels |
Thu, Apr 17, 2008 at 11:10:37 AM
