27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> temporary dimension properties must be broken.
"settings > temporary dimensions >faces" still measures walls on centerlines
even with location line set to Finish Face: Exterior.. how do i get temporary
dimensions to measure walls on "FACES" from end to end? thank you thank you
As temp dimensions lock into the interior faces of an exterior wall, I usually pick on the blue grips of the temporary dimensions so they click to the outside face. You may have to pick one or two times as the grip may cycle to the center of the wall and the second pick will cycle to the exterior face. This works for walls and openings, so the grip will cycle through to an opening's 2 jambs and center.
Like permanent dimensions, you can pick (hold down) on a temp dims blue grip and drag it to a new face and let go. This is especially helpful if I need to fine tune a temp dimension string that is not located exactly on the objects I need to set my dimension from.
LinkedIn Profile:
- http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com |
thanks for responding job..
re-adusting the witness lines to faces is exactly what i was hoping to avoid..
"settings > temporary dimensions > faces" surley must have something to do
with this but changing it there just doesn't do it.. that leads me to believe
"temporay demension properties" must be good for something- but what?
thanks
temporary dimensions |
Wed, Jul 1, 2009 at 10:50:50 AM
Temporary Dimension Property Question |
Tue, Aug 11, 2015 at 9:04:51 AM
temporary dimension disappearing when converting it to permanent dimension |
Thu, Sep 14, 2017 at 9:48:30 AM
adjusting grids using temporary dimensions |
Thu, Nov 22, 2012 at 12:05:29 AM
Reference Plane Dimension |
Sat, Aug 20, 2005 at 7:33:46 PM
