Forums >> Revit Building >> Technical Support >> family editor views
Fri, May 19, 2006 at 5:40:03 PM | family editor views
basia
i'm not proud, but i did a rather stupid thing - i created a custom shelving unit in the family editor, and i unfortunately drew out the entire front elevation while i was in the "floor plan" view. so, when i finished and imported the shelves into my project, they end up flat out on the floor instead of rising up along the wall. is there a way that i can somehow edit the family to fix this?! thanks.
Sun, May 21, 2006 at 5:56:49 PM | RE: family editor views
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes, go to your family, go to side view and rotate, if you have any constraints in the family, you will need to redefine them...
Integrator
KarelCAD
Sheets in family editor
Tue, Jan 10, 2012 at 6:14:35 PM
exploded views and sheet feature in revit family editor
Mon, Mar 24, 2014 at 10:55:30 AM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
No Annotate tab in Family Editor; no detail lines
Tue, Sep 8, 2009 at 3:42:49 PM
Page generation time: 0.7637
