Forums >> Revit Systems >> Technical Support >> keynotes
Wed, Dec 21, 2016 at 4:41:43 PM | keynotes
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I have a revit link that has keynotes by number method "by sheet" but they are blank in my host model, if I open the link they are there and if I change the number method to "by keynote" in the link, they show up in my host.
What is the trick to get keynotes to show up from my linked model when set to by sheet in my host model?
Thanks
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Thu, Dec 22, 2016 at 7:04:38 AM | keynotes
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
bumb
Can anyone assist?
thanks
Thu, Dec 22, 2016 at 7:38:14 AM | keynotes
The sheets in the linked file are not in your project so that can not work.
Thu, Dec 22, 2016 at 7:58:16 AM | keynotes
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
That make total sence and couldn't be more obvious now I have been told.  Thanks Hub.
Due to our workflow and reasons above and beyond what should be, we have to seperate our models, one for design and one for coordination, contract legal reasons.  We still link and share views.  We want to see the Keynotes by sheet from the design model in our coordination model, is there any way to link the sheets to pull that info?  or is it a total redo in the host model?
Thanks
Thu, Dec 22, 2016 at 8:30:36 AM | keynotes
No way for me to test currently.   Try setting up a view that is the same as a view in the linked model then set the link to be by view and pick that view.  I don't know if you will see the keynotes or not.
Thu, Dec 22, 2016 at 9:05:33 AM | keynotes
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
yeah, I tried that before posting and some other tricks too...  No go.  I was hoping that I was just missing something.
What I have done is hidden the linked keynote symbols and inserted the legend from the link and we will just tag the elements thru the link, no big deal.
If you have time, I would be interested in seeing if you could figure out a way to do it.  But your first post makes total sense and eluded me, so I am of the opinion, at current, it can't be done, but magic does happen.
Thanks Hub
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 1.2397
