Forums >> Revit Building >> Technical Support >> wall hatches!
Fri, May 19, 2006 at 11:10:10 AM | wall hatches!
elvis
hi all, why is de wall hatchpattern not oriented on de wall position and rotation. if i do have a pattern of 45 degrees, and my wall is drawn under 45 degrees, then the pattern is parallel to the wall, thats not how is should be, can this be solved? grtz E
Fri, May 19, 2006 at 11:29:33 AM | RE: wall hatches!
arnosandoval
5 Stars: 3 Votes
See Attached, fill patterns can orient now according to its host.
Export to DWG: distinguish Wall hatches from the inner and outher wall lines
Wed, Mar 1, 2006 at 8:34:41 AM
PROBLEM WITH WALL HATCHES
Wed, Mar 16, 2011 at 5:25:54 AM
How To Turn Off Hatches
Mon, Feb 11, 2008 at 3:27:14 PM
Wall Hatches in Section and Plan
Tue, Jun 12, 2012 at 4:44:06 PM
2 hatches on 1 wall?
Tue, Jun 24, 2008 at 3:49:31 PM
Page generation time: 2.1386
