Forums >> Revit Building >> Technical Support >> Crown Molding on Narrow Walls
Mon, Dec 12, 2016 at 10:40:33 AM | Crown Molding on Narrow Walls
RevitUser9000
I want to place crown molding throughout an apartment I'm designing but I've run into a problem on some walls. There are areas in the apartment where a wall will end without meeting another wall and the crown molding doesn't seem to work there. It wont let me click on the small face of the wall though it works fine on either side. I've tried to mold other outside corners without problem. I've included a picture of one instance where it wont apply the molding. I'm using wall sweeps as well.
Mon, Dec 12, 2016 at 11:04:37 AM | Crown Molding on Narrow Walls
marmiketin1
4.5 Stars: 10 Votes
Personally I would probably never model crown molding (just show it in details) but a workaround you could use would be to create a wall type (probably just gypsum board) and use it as a return at all your wall ends. You could then pick that gypsum wall piece for you moulding. Also you could just model in place a sweep using your crown molding profile.
Mon, Dec 12, 2016 at 11:17:04 AM | Crown Molding on Narrow Walls
RevitUser9000
Thank you! That worked. I'm using revit as a starter design before I export to Unreal Engine where moldings not as easy otherwise I wouldn't model it.
Mon, Dec 12, 2016 at 9:54:59 PM | Crown Molding on Narrow Walls
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
With a wall sweep, you could also use Modify Returns tool to fix that end wall problem.
Tue, Dec 13, 2016 at 6:12:36 AM | Crown Molding on Narrow Walls
Most users have never explored the modify return tool and they should.
Excellant answer Pijpiwo!
Crown Molding Help
Thu, Feb 1, 2007 at 7:22:54 AM
How to add crown molding header above a window
Thu, Feb 26, 2015 at 12:57:30 PM
crown molding
Tue, Jun 13, 2006 at 11:44:39 PM
Crown Molding - Cabinetry
Wed, Jun 29, 2011 at 5:30:33 PM
How do I add crown molding to wall cabinets?
Mon, Sep 22, 2014 at 7:13:43 AM
Page generation time: 0.3820
