Forums >> Revit Building >> Technical Support >> how to stop snapping to floor hetch?
Sun, Dec 4, 2016 at 5:08:50 AM | how to stop snapping to floor hetch?
BenNoBe
how can I stop revit from picking hetch floor lines?
I use revit 2017
Ben
Sun, Dec 4, 2016 at 10:06:12 AM | how to stop snapping to floor hetch?
Learn to use the tab key and the funnel filter.
Sun, Dec 4, 2016 at 12:44:09 PM | how to stop snapping to floor hetch?
BenNoBe
Thanx for your answer,
I'm femiliar with this methods.
With this methodes i have to change the setting every time.
My question is: is there a way to permanetly stop the snapping to the floor hetch (not the borders, just the hetch)?
Ben
Mon, Dec 5, 2016 at 9:28:54 AM | how to stop snapping to floor hetch?
Turn it off in view.
Wed, Dec 7, 2016 at 12:51:00 AM | how to stop snapping to floor hetch?
BenNoBe
so there is no way to stop snapping to a hetch other than turning every hetch off in the specific view?
Wed, Dec 7, 2016 at 10:57:38 AM | how to stop snapping to floor hetch?
You really have not explained what you are doing so our answers are limited.
BTW - I assume by 'Floor hetch', you mean a material HATCH pattern assigned to the floor surface but you really don't say that either.
Wed, Dec 7, 2016 at 4:32:36 PM | how to stop snapping to floor hetch?
BenNoBe
sorry for my lame english...
that exactly what i ment.
when i'm working in a plan view, for example, and i'm using the align command, i can align to the material hatch pattern assigned to the floor surface.
is there a way to avoid that option completely?
Thu, Dec 8, 2016 at 6:35:49 AM | how to stop snapping to floor hetch?
I have given you your options and the best is to use the tab key to select what you want to align to.  It is a very simple solution.
Tue, Dec 13, 2016 at 6:59:21 AM | how to stop snapping to floor hetch?
BenNoBe
Thanx
Wed, Mar 27, 2019 at 6:01:09 AM | how to stop snapping to floor hetch?
seychellian
I am trying to draw over a pool surface with 20mm mosiac tiles covering it and the snapping is a nightmare. Tabbing isnt really a solution either.
Anyone got a more practical solution?
curtain wall sketch snapping problem
Wed, Aug 12, 2009 at 8:54:07 AM
Walls stop short of intended level - why?
Wed, May 23, 2007 at 8:36:31 AM
Spot Elevations - Random snapping.
Tue, Feb 21, 2017 at 6:19:05 AM
Keeping walls from snapping
Fri, Jul 21, 2006 at 12:06:03 PM
wall floor finishing joint
Mon, Nov 23, 2009 at 4:56:30 AM
Page generation time: 0.2855
