20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Method to Align Section view to modeled elements
103 Posts No Rating |
I have a portion of building that is set to an odd angle and I made a quick section cut without realizing that it was not aligned properly to the view. Now when I open the section view, I can zoom in and see that everything is off kilter by a hair. Is there a way to re-align the section view with the modeled elements?
I tried rotating, but there is no snappable part of the section to guarantee that the correction is any better. I am using version 2016.
Why not just cut a new section that is perpindicular?
I have rotated sections in the past but the process is not easy since the rotation center is not on the section cut. You have to move that point. The other problem is Revit doesn't like small increments.
HELPPPPPP |
Thu, Apr 23, 2020 at 9:57:30 AM
DIFFERENT LINE THICKNESSES FOR STRUCTURAL FRAMING ELEMENTS IN SECTION |
Tue, Sep 28, 2010 at 7:16:14 AM
rotating elements in section view |
Thu, May 1, 2008 at 11:24:27 PM
Topo Thickness Issue in 3D view |
Thu, Jun 13, 2024 at 7:05:48 AM
None of the created elements are visible in Section View |
Wed, Mar 25, 2009 at 1:48:53 PM
