Forums >> Revit Building >> Technical Support >> temporary dimensions
Thu, May 18, 2006 at 9:34:20 PM | temporary dimensions
vector23
vector23 Avatar
2 Stars: 16 Votes
why do temporary dimensions always measure to centerof wall even if i change "temporary dimension properties" to faces? i'm drawing walls to "finish face exterior" and when i type in the dimension the temporary pops up different. it seems to measure to centerline no matter what i do.. dimensions are babys' first steps in revit.. must be somebody that knows.. is there some place to control the behavior of temporary dimensions other than "settings> temporary dimensions"?
Wed, Jul 1, 2009 at 10:50:50 AM | temporary dimensions
revking
Just grab the temp dim. middle grip and change temp. dims location. Then you can change dimension from there.
Temporary Dimensions and Wall centerlines
Thu, Oct 20, 2011 at 1:31:20 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
temporary dimensions require me to pan to see them
Sat, Mar 26, 2016 at 9:52:41 AM
Mon, Jun 30, 2014 at 9:57:47 AM
Page generation time: 1.0882
