Forums >> Community >> Newbies >> Stair cut pattern in plan
Fri, Nov 25, 2016 at 10:54:38 AM | Stair cut pattern in plan
abdurrahmanjoomye
Hi everyone,
How do I get stairs to appear cut in the same way as walls appear when cut?
I want to the cut plane that is cut to appear filled, in the same way that it appears in a section for instance.
This helps understand the space better.
Below is an example of the end result expected. (I used a hatch region to work around the problem, but this is very "un-Revitly").
Fri, Nov 25, 2016 at 12:02:35 PM | Stair cut pattern in plan
Revit will not do that, it only cuts the stairs 'vertically' using a break symbol.
Fri, Nov 25, 2016 at 12:47:02 PM | Stair cut pattern in plan
abdurrahmanjoomye
Thank you WWHub,
Is there a way however to get revit to consider the stair as a solid volume and cut through it?
Or is there a way to creat e a custom cut symbol to do the trick?
Sat, Nov 26, 2016 at 10:32:57 AM | Stair cut pattern in plan
You can create any detail element that you want.
Sat, Nov 26, 2016 at 2:18:00 PM | Stair cut pattern in plan
abdurrahmanjoomye
Ciuld you please tell me what would be the first steps to create a detail element?
Stair Surface Pattern Not Displaying
Wed, Sep 8, 2010 at 10:05:09 AM
Plan Regions Cutting Stairs
Thu, May 26, 2011 at 6:14:12 PM
cut pattern in section
Wed, Jun 1, 2011 at 4:30:59 AM
Cut Pattern for Curtain Panel Not Showing in Plan
Fri, Sep 5, 2014 at 6:25:57 PM
stair plan
Wed, Oct 26, 2011 at 12:31:01 PM
Page generation time: 0.8089
