15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Incorporate linked Revit views into your project (Revit2017)
Hi!
I wonder if anyone has dealt with this before: I have a main revit project link three other revit models. Basically it's a sloping site with 3 duplexes
sitting on different elevations and facing different angles. Now if I try to do the working drawing in the main model, I will need to incorporate the views from each individual revit model into the main model. Because it's much easier to tweak the elements if I work on plans and sections within the linked models. But I couldn't find a way to bring those views into the main model, and in the end of day I don't want to combine the sheets from all the three linked revit together to make a whole.
Any suggestions? Thanks!
And here's a jpeg from the site view
You can use 'By Linked View'
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-62DD9C0C-C689-4D08-B9E2-4CE53A993B27
Edited on: Fri, Nov 25, 2016 at 11:56:56 AM
ThankS!! I think that's what I need.
Linked Cad & Views across projects |
Thu, Oct 25, 2007 at 10:54:18 AM
I can't work out how to incorporate a wall I downloaded from NBS into my project |
Wed, Jun 14, 2017 at 11:40:56 AM
Detail Sharing across a multi-model project.... Need some advice. |
Tue, Aug 11, 2009 at 6:27:57 AM
LInked AutoCAD details into Revit 2009 workset project |
Tue, Jun 28, 2011 at 5:07:32 PM
Reloading Linked Files - Lost Sheet Views |
Tue, Aug 23, 2011 at 8:52:01 AM
