18 Users Online (16 Members):
Forums >> Revit Systems >> Technical Support >> Room tags to match linked model tags
Hello,
I am creating furniture layouts on a linked architectural model that has many levels. In order to run a schedule of number of furniture items a given room, I need to add room tags to my furniture model. When I create a rooms (RM) it adds a tag that does not match the linked architectural room tag. I need them to match. Do I have to edit each roomtag manually to match or is there a way to universally match the linked room tag? Hope there a magic command that would do this quickly and save me to time manually change 300 some rooms. Thank you.
I suppose you want to edit in the tag some information you need in the schedule.
See if this helps.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Collaborate/files/GUID-EE92017A-F29C-4568-A51F-CAFA7D714EE7-htm.html
Edited on: Sun, Nov 20, 2016 at 3:57:38 PM
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Opaque Room Tags |
Thu, Nov 5, 2015 at 11:06:19 AM
Room Tags not visible in a linked file - Revit 2014 |
Tue, Apr 4, 2017 at 5:54:04 PM
How to make room tags in a linked file visable? |
Thu, Jul 30, 2015 at 1:12:22 AM
2011 - Room Tags from a linked file |
Thu, Aug 19, 2010 at 4:10:54 PM
HIDDEN ROOM TAGS WITHIN LINKS |
Mon, Nov 14, 2011 at 9:20:17 AM
