Forums >> Revit Building >> Technical Support >> Symbolic Line Draw order
Mon, Nov 14, 2016 at 9:42:56 AM | Symbolic Line Draw order
paudy86
Hi,
I am having problems getting things to read as they should.
Basically we have a linked CAD file from another consultant which we need to show in most of our views. To avoid it disappearring behind some of our Revit elements we have offset it up in the air above these elements. However the hatches and linework in th CAD file are now appearing above symbolic lines from the numerous families visible in the view.
Is there a way to have symbolic lines take priority and display over absolutely everything else in a view?
We are using Revit 2016 for this one.
Thanks in advance,
P
Mon, Nov 14, 2016 at 10:19:36 AM | Symbolic Line Draw order
Bad practice.   The CAD file you are using has been linked as a 3D CAD and that's why you can 'move it up'.  As such, it can hide model elements.   Model elements that have symbollic linework act the same as a model element, other model elements (your CAD) can hide them.
draw order in revit 2010
Tue, Sep 23, 2014 at 1:24:31 PM
Symbolic/Model lines bug!
Wed, Oct 21, 2009 at 1:39:23 AM
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Symbolic lines in elevation
Thu, Jan 10, 2008 at 7:12:53 PM
Plan adjustable door swing issue
Mon, Oct 1, 2012 at 9:13:26 PM
Page generation time: 0.7119
