Forums >> Revit Systems >> Technical Support >> Which template should I use if I want to place a generic model on a linked floor
Mon, Nov 14, 2016 at 4:29:29 AM | Which template should I use if I want to place a generic model on a linked floor
simonn12002
I work on revit projects using linked architecture - adding kitchens and bars to architects models.
Recently I have modelled face based models to indicate electrical outlet positions on walls.
The problem I am having is placing drain pipe pop-ups on floors.
Revit does not recognise linked floors as 'floors', nor does it recognise them as 'faces'.
Which leaves me a little stumped. Can anyone offer a solution to this problem?
Which generic model template should I use if I want to place a model on a linked floor?
Mon, Nov 14, 2016 at 5:09:05 AM | Which template should I use if I want to place a generic model on a linked floor
Elnazer2
4 Stars: 5 Votes
you cannot detect the linked model with any of the face based nor the wall or floor based templates , i think you have 2 options either to use workplane families and put your components on levels , or copy/monitor walls ( or Floors ) and use face based or wall based families
Mon, Nov 14, 2016 at 8:55:52 AM | Which template should I use if I want to place a generic model on a linked floor
Revit has a built in process for this called copy/monitor - rad about that in your HELP.
Tue, Nov 15, 2016 at 2:27:42 AM | Which template should I use if I want to place a generic model on a linked floor
simonn12002
Hi Elnazer2. Sorry I should have mentioned that I have successfully used face based models on linked walls. I only encounter problems when I try to host these face based models on linked floors.
Tue, Nov 15, 2016 at 10:37:52 PM | Which template should I use if I want to place a generic model on a linked floor
Elnazer2
4 Stars: 5 Votes
yes the face based families are also working on floors in 3d views , i just checked that , but then you will have to switch all your families to face based templates , its easier to copy/monitor
Problem with adding analytical lines into Generic Model line template
Wed, Apr 10, 2013 at 3:31:06 PM
linked revit model disappears when I edit a floor or do an 'in place' model
Mon, Dec 17, 2012 at 8:01:15 PM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:37 AM
Convert Generic Model floor based Generic -> Generic Model
Fri, Jun 27, 2008 at 3:02:18 PM
Unable to Place Components in Linked files
Wed, Aug 10, 2011 at 3:11:59 PM
Page generation time: 2.1307
