Forums >> Revit Building >> Technical Support >> File Management - Large Projects
Mon, Nov 14, 2016 at 2:37:22 AM | File Management - Large Projects
Reddrev
I am working in China and a local REVIT expert is insisting that EVERY floor level, should be in a seperate file.  While i can see the merit of this if its a large project and there are indviduals working on a particular floor plan / model then linking them all together into a master file.   But they are insisisting all projects no matter of the size should have seperate floor level files etc.
Apart from workflow, amount of available staff for a project etc  Are there any accepted work practices for seperating a project into many files.
we do a lot of high rise apartment blocks (100 to 150m)  all with same floor plans at each level.  Personally I would do all this in one file, group each apartment type at the first main level, then copying up the building.
It maybe this floor per file practice comes from the limitation of the computer system, I am not sure.
any suggestions dialog etc   would be most welcome.
Many Thanks
Mon, Nov 14, 2016 at 8:54:11 AM | File Management - Large Projects
Your co-worker does not understand Revit.   Only have seperate files for seperate disciplines, otherwise use worksets as required to control very large projects.
Mon, Nov 14, 2016 at 10:46:41 AM | File Management - Large Projects
archigrafix
5 Stars: 4 Votes
How many people work per floorplan? 10-20? Are we talking very large floorplans like hospital kind of project?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
the large projects are not to be solved by (Soft) solution
Mon, Dec 30, 2013 at 8:44:10 AM
Managing large projects in Revit? Site with multiple units/buildings.
Wed, Jan 9, 2008 at 7:53:31 PM
Revit File Management
Fri, Jan 21, 2011 at 11:24:05 AM
Revit 2013 Model Review Management File
Fri, Mar 22, 2013 at 12:20:14 PM
Large project with multiple buildings - file management
Mon, Feb 25, 2013 at 4:32:17 PM
Page generation time: 2.6431
