Forums >> Revit Building >> Technical Support >> Sheet order in the project browser
Mon, Nov 7, 2016 at 9:51:53 AM | Sheet order in the project browser
aaronkennedy
I want to set my projects up so my sheets appear in the browser in the order they will appear in the plan set and hopefully have this carry over into the index on my cover sheet. I want to order them similar to this.  Cover sheets (G), civil sheets(C), structural(S), demolition(D), architectural(A), mechancial(M), electrical(E), plumbing(P), etc.  I have tried filtering and sorting but I cannot seem to make it work right.  Any help would be appreciated.
Thanks
AAron
Mon, Nov 7, 2016 at 10:10:53 AM | Sheet order in the project browser
As I wrote on a similar thread below:
Add a shared parameters to your sheets called sort-order and use that in your drawing index.  (You don't have to show the value in the index.)  You will have to add this value yourself.
You can then set the browser to sort using this as well.
Mon, Nov 7, 2016 at 10:25:37 AM | Sheet order in the project browser
aaronkennedy
Thank you, I searched it and looked at several threads but could not find it. I was probably just using the wrong search terms.
AAron
Sheet order in Project Browser
Tue, Sep 23, 2014 at 10:58:43 AM
Sheet Number Order
Wed, Oct 15, 2008 at 10:30:38 AM
PROJECT BROWSER ORDER
Tue, Jan 15, 2008 at 9:29:51 PM
missing sheet in project browser
Fri, Aug 22, 2014 at 7:13:58 AM
Project Browser Sorting Order Question
Thu, Jul 28, 2016 at 5:01:52 AM
Page generation time: 0.6426
