13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Call out View
Hi
I created a elevation view in the floor plan and when I create a callout view the elevation tag wont show in the callout view.
Also in the callout view there is no option to create a elevation view. How can I see the elevation tag in the callout view?
Thanks Ed Knight
copy all the 2d items you want to copy ( In elevation ) and paste aligned to the same view ( In Callout )- but most likely you will have to adjust the Tags And dimension sizes to fit in the new scale of the callout.
Thanks for the reply.
Its the elevation tag, that is not a 2D item, that won't show up in the call out view.
First, are the elevation callouts on in VG settings?
If so, then change your view scale to something larger then your current setting and the tags should show. Now click on one of them and look at the properties ..."hides in views coarse than"....
Thanks so much I had the level set to Course.
Changing options on call out views so able to see on all floors |
Thu, Oct 29, 2009 at 6:33:51 AM
crop call out |
Sat, Mar 3, 2012 at 1:06:47 AM
Call outs in Revit |
Wed, Jun 11, 2008 at 8:39:23 AM
Call outs withing call outs |
Sun, May 10, 2009 at 3:35:42 PM
Can I call out from a legend view |
Thu, Oct 15, 2015 at 10:57:52 AM
