Forums >> Community >> The Studio >> cutting through a sweep
Thu, May 18, 2006 at 9:06:54 AM | cutting through a sweep
shytiger
I'm using a sweep profile to generate a seating bowl for a stadium. Basically just taking the tranverse section of the bowl and using it as a sweep proile then lofting it around a path which is the shape of the bowl. My problem is cutting through the bowl to allow for the openings of the vomitories. Building the bowl using floors allows for openings to be cut but it's way too time-consuming to build a bowl using this method. Any suggestions from anyone would be appreciated on how to cut holes throuh a complex shape generated by a sweep. Thnks CP
Thu, May 18, 2006 at 10:57:25 AM | RE: cutting through a sweep
shytiger
figured it out...once the bowl is lofted it's just a matter of editing. Once in edit mode its just a matter of using the void form and adding an extrusion. Next is to link the vomitory wall to the void so the opening will adjust to the v walls.
Cutting a Sweep - Brick Detail
Sun, Jan 4, 2015 at 3:37:41 PM
Solid Sweep Not Cutting in Section
Mon, Dec 18, 2006 at 2:06:34 PM
Vertical Wall Reveals not cutting sweep
Wed, Nov 8, 2006 at 9:23:11 AM
Cutting Solid Sweep?
Sun, Apr 23, 2006 at 11:03:51 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Page generation time: 0.1100
