14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Override Phase Filter for Specific View only
103 Posts No Rating |
I understand that Manage/Phases can be used to dial in the graphic settings and overrides for phases for all views in a project. I also undertand that Phasing settings trump any graphic setting applied downstream to a specific element or view template. In other words, any graphic override applied to a paticular existing element will be ignored and follow the Phasing filter override instead. Is there a way to override the phasing filter settings for one view only?
In my case, I need to show existing to remain cut sections as diagonal dashed hatch for 1/4" wall sections and details, but I also want to show existing to remain cut sections as solid gray for 1/8" building sections? Is there a way to do this?
I am using Revit 2016.
Not really, you can apply graphics override by element or set up a filter in VG. Unless, I misunderstood your question.
Edited on: Fri, Nov 4, 2016 at 12:45:19 PM
Filter by Phase |
Thu, Apr 15, 2010 at 10:37:34 AM
VG and phasing not working |
Thu, Jun 26, 2008 at 7:29:16 AM
Graphics override by phase? |
Tue, Mar 31, 2009 at 1:01:09 PM
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
Phase - Graphiv Override |
Thu, Dec 10, 2009 at 11:10:11 AM
