Forums >> Revit Structure >> Technical Support >> Floor plan is missing in view
Fri, Nov 4, 2016 at 7:43:17 AM | Floor plan is missing in view
mark7321
I'm using Revit Structure 2015. I had no problems when I left for the day at 5:00 but when I opened the model the next day none of the framing plans were visible on the screen. I had to type ZF (zoom fit) to make the framing plans appear. All of the framing plans appeared except for the one. When I click on that framing plan the crop region appears empty. When I do a crossing window It chooses elements as if they are there. When I go to the sheet view the framing plan can be seen. Just in the working view the framing plan doesn't appear. What is going on?
Fri, Nov 4, 2016 at 10:03:46 AM | Floor plan is missing in view
Your questions are strange:
"I had to type ZF (zoom fit) to make the framing plans appear"  ZF in every plan or ZF and you see all the plans?  If this is multistory, the framing would be in multiple views.
The secound question sounds like the view you are in and the view on the sheet are not the same view.
I see you have been around for awhile so the beginner mistakes I think I see should not be.   If that is the case, then you possibly have a video card issue and you may not have installed needed updates.   You don't say what Revit release and what update you are on.   You should always include that in your posts.
Missing Floor Plan from Browser
Mon, Nov 5, 2012 at 6:31:47 PM
Multiple sheets from same floor plan view with different scales?
Fri, Aug 1, 2008 at 12:01:43 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Setting the View for Floor Plans
Sun, May 20, 2007 at 8:26:43 PM
Structural plan is missing from View tab> plan views
Mon, Apr 29, 2013 at 8:04:26 AM
Page generation time: 3.7947
