35 Users Online (33 Members):
Forums >> General Discussion >> Revit Project Management >> Stacked Wall Changes & Wall Tags
8 Posts No Rating |
Afternoon Everyone,
Working on a project in Revit currently and am changing a lot of stacked walls to basic walls consisting of one wall type. In doing so I've run into the following issues:
-Wall tags dissapear when the wall is changed error
-Dimension strings become invalid and flash warning messages
Regarding the first issue, am i wrong to think Revit is sophisticated enough to allow the tag to remain but alter its text per the new wall type? Or when walls change is it required that a wall be re-tagged every single time?
Regarding the second issue, I've read a lot about location lines and even after listening to the advice of several forum members this still seems to be an issue. Immediately when the wall is changed, the wall type will either shift positions slightly or remove a dimensions or both. I suppose I'm just looking to see if this is a constant problem in Revit or whether there is a sure-fire way to fix something I'm doing wrong.
Been a long time since I posted on here and I would appreciate any input and help i can get!
Thanks,
Stacked walls are just that - a stack of different walls. When a wall type in that stack is deleted, then the tag will go away too. Otherwise, when changing a normal wall to a different type type, the tag will change accordingly.
The same is true of dimensions.
Wall Tags not unique for stacked walls [ 1 2 ] |
Fri, Sep 16, 2016 at 10:17:50 AM
17
stacked wall line visable on the wrong side? |
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
Breaking apart a Stacked Wall Issue |
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems |
Tue, Oct 14, 2008 at 12:50:52 PM
