Forums >> Revit Systems >> Technical Support >> Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM | Cable tray tee
AJKS
I'm using the system cable tray fittings. The standard cable tray tee cuts the cable tray it butts upto into two and goes all the way across to the far wall. Our cable tray system tee only uses an edge tee that only cuts the wall the tee touches. See attached image, the part in green is what we need to accomplish. The part must be able to automatically added as the system tee is.
Cable Tray Clearance
Mon, Mar 24, 2014 at 10:44:48 AM
Cable Tray- Revit MEP 2013
Fri, Oct 5, 2012 at 8:29:45 AM
Revit 2015 - Ladder Cable Tray
Mon, Feb 29, 2016 at 5:05:14 PM
How to do Cable Tray with Real Material Color (Not just filter color)
Wed, Feb 18, 2015 at 3:14:07 AM
Cable Tray
Fri, May 9, 2008 at 7:28:19 AM
Page generation time: 4.6622
