Forums >> Revit Building >> Technical Support >> REVIT 2017 railing not showing up on floor plans
Mon, Oct 31, 2016 at 7:06:48 PM | REVIT 2017 railing not showing up on floor plans
FIXERS
Hello!
I wonder any one has encountered this before. My stair railing is partly missing from my floor plan(stair plan 1.pdf). However when I make a callout for the staircase specifically it showed up perfectly again(see stair plan 2). I use the same viewing template for both the floor plan and the callout. their view range is exactly the same, no filter, no element override, no overlay..etc, object styles are the same,  just the railing behaved weird. Anybody can help? THanks!!
Tue, Nov 1, 2016 at 1:42:53 PM | REVIT 2017 railing not showing up on floor plans
renderforfun
4.5 Stars: 6 Votes
Looks glitchy to me....that is really weird because where your hand rail is missing it still shows the handrail mounting bracket half way up the ststairs. Check the options are inside the staitcase itself for visibility options, I know there are a few things you can toggle but i really think you should shut down and re-open.  Smile  good luck and while your add it down forget to notate Up & Dn on the stairs as that is important as well.  Looks like a good set of drawings though, i wouldn't mind seeing more of the set.
Edited on: Tue, Nov 1, 2016 at 1:46:05 PM
Tue, Nov 1, 2016 at 1:48:44 PM | REVIT 2017 railing not showing up on floor plans
Also, do you have all service pacs installed?
After Service Pack 2 is applied successfully, the build number specified on the Help > About dialog will be 20160720_1515.
Tue, Nov 1, 2016 at 2:06:05 PM | REVIT 2017 railing not showing up on floor plans
renderforfun
4.5 Stars: 6 Votes
thinking about it more it could be the extents of one of those annotations you have.  I notice it is happeneing at the very top right of your stair where your text box is.
Tue, Nov 1, 2016 at 2:11:15 PM | REVIT 2017 railing not showing up on floor plans
FIXERS
Thanks @renderforfun! I incline to believe it's a glitch. I think I checked through all the visibility settings including stairs and railings and compared these two views, the settings are the same, but problem exists, even after I reopen it multiple times. The stair direction note is automatic, and apparently it shows the stair direction from stairs DOWN BELOW... Couldn't figure out why.
Thanks @ WWHub, I am currently using sp1, will download sp2 and see how it turns out..
Tue, Nov 1, 2016 at 2:30:24 PM | REVIT 2017 railing not showing up on floor plans
Please cut and post a stair section that is a reverse of that 1/A307
Tue, Nov 1, 2016 at 2:47:14 PM | REVIT 2017 railing not showing up on floor plans
FIXERS
@WWHub, sure please see attached. The pdf I uploaded earlier is from 4th floor.
Wed, Nov 2, 2016 at 6:23:57 AM | REVIT 2017 railing not showing up on floor plans
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Some glitches could be fixed by cutting the offending element and pasting it back aligned to same place. Hope it helps.
Wed, Nov 2, 2016 at 6:52:28 PM | REVIT 2017 railing not showing up on floor plans
FIXERS
Thanks @pijpiwo, LOL As mus as I love use that trick to fix over constrained items. It doesn't help in this case unfortunately.
Thu, Nov 3, 2016 at 7:05:47 AM | REVIT 2017 railing not showing up on floor plans
I am not yet using 2017 and can not check this out but this is not a normal problem.
Mullions now showing on all plans?
Thu, Nov 29, 2012 at 9:46:32 AM
Revit 2014 - railing showing in plan view
Wed, Sep 3, 2014 at 1:04:10 PM
Revit MEP: Pipes not showing up in floor plans ??
Mon, Feb 2, 2009 at 12:04:19 PM
plan callout showing up under Floor PLans in project browser
Thu, Apr 16, 2015 at 1:48:04 PM
Staircase Railing cant extend to floor
Wed, Mar 26, 2014 at 8:33:49 AM
Page generation time: 2.6044
