Forums >> Revit Building >> Technical Support >> View Range Problems
Mon, Oct 31, 2016 at 4:05:14 PM | View Range Problems
mrdiesel
Im having trouble configuring my view range. No mater what I do I can not get elements from a lower level to go aways.
For example.
Level 1 - Main Floor is showing the foundation below it. even with a floor in place.
The view ranges is set as follows:
Top: Associated Level, Offset 8'
Cut Plane: 4'
Bottom: Associated Level, 0'
View Depth: Associated Level, 0'
it also seems to be messing with my electrical layout as well
Mon, Oct 31, 2016 at 6:04:26 PM | View Range Problems
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In the view properties, make sure Underlay is set to None.
Mon, Oct 31, 2016 at 6:06:38 PM | View Range Problems
mrdiesel
holly..... $^*&@.... that was easy!
thank you very much. Im going to go beat my head on a wall now
View range problems with framing plans
Tue, Feb 23, 2010 at 1:48:16 PM
View Range problems- seeing wall detail
Fri, Jun 6, 2008 at 8:56:57 AM
view range
Fri, Sep 7, 2007 at 2:28:04 AM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
Page generation time: 4.6386
