Forums >> Community >> Newbies >> Architectural font issue
Wed, Oct 26, 2016 at 12:26:03 PM | Architectural font issue
sdeeut
I'm new to Revit, and this site.  I wanted an architectural font in Revit and tried using an old .SHX font I've been using in Autocad FOREVER.  Reading about Revit, I understand it just uses fonts found in the Windows/Fonts directory.  So I searched the internet and came up with a great architectural .TTF font.  I installed that into the windows/fonts folder and changed my font type in my dimensions to it and it worked great.  I then tried to change the font type in the leader text I was using and all that shows on the screen are boxes instead of letters?  Why does the new font show up great in dimensions, but not as a font?  Any help would be appreciated.
Wed, Oct 26, 2016 at 1:27:16 PM | Architectural font issue
The font you are using was not built correctly.   Check out the similar threads below and you may find a font that works right.
Wed, Oct 26, 2016 at 2:39:09 PM | Architectural font issue
sdeeut
Thank you.  Actually right after I posted that I found a similar thread, and there was a font attached, so I grabbed it and tried it out and it worked great.  Not exactly as nice as the font I was trying to use, but it's still a good one.  Thanks for the reply.
Normal practice, how to show structural elements in architectural.
Tue, Dec 10, 2013 at 8:44:10 AM
Architectural CAD Drawing - Architectural drawings on Computer in digital format
Fri, Dec 19, 2008 at 3:31:17 PM
Architectural fonts [ 1 2 3 ]
Fri, Apr 5, 2013 at 8:40:54 AM
30
How do you link together Architectural model with mechanical model?
Wed, Jul 25, 2007 at 9:30:04 AM
Font
Thu, Feb 25, 2016 at 6:39:37 PM
Page generation time: 1.0384
