Forums >> Revit Building >> Technical Support >> Problem: wall's extrusion profile covers windows and doors
Wed, Oct 26, 2016 at 3:42:24 AM | Problem: wall's extrusion profile covers windows and doors
unnbe
Hi everyone!
I've added an extrusion profile to a wall, to create a sort of boiserie (h: 2 meters). Actually, this profile "close" every opening of the room (windows and doors). From the extrusion profile dialog box I've checked "cuttable" but nothing changed...
How can I figure it out?
Thanks
Wed, Oct 26, 2016 at 3:46:51 AM | Problem: wall's extrusion profile covers windows and doors
unnbe
(I suppose this is depending by the window and door family that I uploaded in my project...)
Wed, Oct 26, 2016 at 9:55:49 AM | Problem: wall's extrusion profile covers windows and doors
You must not have done what you said.  The below assumes only one wall - not mutltiple walls.
  1. If you added an extrusion to the wall definition, then that would have been cut automatically by windows or doors.
  2. If you added a wall sweep to the wall then that too would be cut at windows and doors.
  3. So instead, you must have added an in-place sweep.   That will not be cut, you will have to add a void to cut that or use seperate sweeps.
Wed, Oct 26, 2016 at 10:18:05 AM | Problem: wall's extrusion profile covers windows and doors
unnbe
I made a 100% profile wall extrusion.
Instead, I uploaded a new window familly and it works... So... there should be a problem with the previous familiy...
In the picture attached, the "old" window is in the middle.
Edited on: Wed, Oct 26, 2016 at 10:21:50 AM
Wed, Oct 26, 2016 at 10:41:53 AM | Problem: wall's extrusion profile covers windows and doors
I guess I don't see the wall extrusion you were having problems with unless you mean the multi-colored area.   If you did an extrusion for this then I have a better solution for you.  Use a thin wall and join that wall to the other wall.   We do that all the time for wall veneers like tile and stone.
Wed, Oct 26, 2016 at 10:47:26 AM | Problem: wall's extrusion profile covers windows and doors
Check out this thread for my explanation of using this thin wall.
Wed, Oct 26, 2016 at 10:57:18 AM | Problem: wall's extrusion profile covers windows and doors
unnbe
Yes, the "multi-colored area" is the stone cladding, that is the profile extrusion.
I will learn your method, many thanks!
Stone wall covers door and window trim?
Thu, Jan 3, 2008 at 8:50:32 AM
Same Wall, Different Problem
Sun, Sep 24, 2006 at 8:00:48 PM
Wall host does not cut when meeting with windows
Wed, Apr 26, 2006 at 6:12:56 PM
window opening doesn't show in floor plan view
Mon, Oct 3, 2005 at 7:59:15 PM
Wall reveals and sweeps being 'over-ridden' by wall based void family.
Fri, Jan 22, 2010 at 4:39:24 AM
Page generation time: 5.6840
