16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> curtain walls aluminium corner profile
135 Posts No Rating |
hi all,
someone knows how to creat a 45 degree aluminium corner profile for a curtain wall system?
I also need more parameters to displace de mullions by a certain distance not only an offset in one direction.
grtz
E
Corner mullions are a special creature and you can't use custom profiles to create them. You would need to use the trapezoidal mullion for a 45° corner.
If you are using a curtain system (sounds like you are), you can select any individual grid. You'll see a pin appear, click this to unpin its position/settings. Now you can freely move it to the appropriate location.
HTH.
Curtain walls |
Mon, Nov 7, 2011 at 10:28:33 AM
Changing render colour of aluminium cladding |
Thu, Mar 22, 2012 at 12:40:00 PM
corner join |
Tue, Mar 14, 2006 at 3:52:38 AM
Commercial Aluminium windows |
Mon, Oct 31, 2005 at 7:57:32 AM
Corner Mullions |
Fri, Dec 6, 2013 at 11:05:58 AM
