25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> North point to T-Block
15 Posts No Rating |
I have have my north point added as a .jpg but would like to be able to change it with in a drawing.
Can you make a tag link to a T-block?
Would this way be best way?
if this is stupid how have others done it?
I've integrated a north pointer into our titleblock that is parametric.
Basically its a symbols with an angle parameter that is then linked into the titeblock family to enable it to be change when in a project.
I've also added a visibility parameter to it so i can turn it off in section sheets etc...
Is that what you're after?
9 Posts No Rating |
Is there a way to link the angle to project north / true north? or does the angle have to be added manually?
Unfortunately no, there isn't a way to link it to your project/true north direction. It would be awesome if we could do that.
Thank you, and sorry for the late reply I forgot to tick notify !!
I have used a symbol now and just rotate it. cheers Again
North Point and project orientation |
Wed, Nov 17, 2010 at 12:38:54 PM
North point on sheet |
Mon, Aug 10, 2009 at 9:20:19 AM
North Arrow |
Tue, Jan 16, 2007 at 9:24:44 PM
Rotation of north point |
Fri, Jun 23, 2006 at 1:50:57 AM
Insert North Point Annotation Symbol |
Thu, Aug 4, 2011 at 1:04:42 AM
