Forums >> Revit Building >> Technical Support >> Calling Out a 2D Detailed Section
Mon, May 15, 2006 at 7:05:33 PM | Calling Out a 2D Detailed Section
Letmethinking
Hi All, We draw quite a bit of details in our sections. If I Detail my Sections and do a callout. Do I have to redraw the componants used and redetail it?
Mon, May 15, 2006 at 8:07:18 PM | RE: Calling Out a 2D Detailed Section
gdoorn
1 Stars: 1 Votes
What i have found works, is if you duplicate the section with detailing then adjust the crop region to clip only the part you want. this keeps the detailing you did, and automatically adds a callout. then you can assign this new "section" to a detail category, and it will work great. that is what i have been doing. hope this helps.
Mon, May 15, 2006 at 8:09:44 PM | RE: Calling Out a 2D Detailed Section
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Or just select all your 2D geometry and copy and paste aligned into your callout.
duplicate construction section with detailing error
Fri, Jun 24, 2005 at 5:21:58 PM
Calling out section in more than one place
Tue, Jul 29, 2008 at 12:18:12 PM
Detailed section elements
Tue, Mar 16, 2010 at 3:13:53 PM
detailed wall sections
Thu, Mar 27, 2008 at 2:10:16 PM
Section Callouts Dissapear w/Level Change
Tue, Aug 19, 2008 at 1:45:27 PM
Page generation time: 1.0185
