Forums >> Revit Building >> Technical Support >> How do you make cantilevered Roofs?
Mon, May 15, 2006 at 9:59:21 AM | How do you make cantilevered Roofs?
keeper
I was wondering how to make cantilevered roofs. Do you use the basic roof command or do you make a generic family
Mon, May 15, 2006 at 11:06:12 AM | RE: How do you make cantilevered Roofs?
arch00
I just use the basic roof command and draw the roof to where the cantilever will go to. Gar
Mon, May 15, 2006 at 1:15:32 PM | RE: How do you make cantilevered Roofs?
Thread Post Kudo! #3
bolandereric
One thing that you can do is put a wall in the location where it bears create your roof with that wall and then delete the wall. It works great.
Mon, May 15, 2006 at 4:59:28 PM | RE: How do you make cantilevered Roofs?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You don't need walls to exist in order to insert a roof...
Mon, May 15, 2006 at 5:25:06 PM | RE: How do you make cantilevered Roofs?
bolandereric
I know that you do not have to have walls to insert a roof. It makes it eaiser when trying to get the overhang to match with the rest of the building.
Mon, May 15, 2006 at 7:17:59 PM | RE: How do you make cantilevered Roofs?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. You can draw a roof by footprint with or without the walls but there are some 'Must Kmow' behavours. Once you know these tendencies you'll be rock'n Below are a couple great video CADCLIPs explaining the in's and out's of roof alignment and roof edges right click and 'save target as' to download. http://www.dgcad.com/downloads/CADCLIP-REV-VARYING-ROOF-PLATES.wmv http://www.dgcad.com/downloads/CADCLIP-ROOF-EAVES-ALIGNMENT.wmv * Also check out www.revitrocks.com or www.dgcad.com for more free CADCLIPs and tutorials
Cantilevered roof cable an brackets
Fri, Oct 24, 2008 at 3:51:55 AM
Tapered cantilevered beam with openings
Mon, Aug 14, 2006 at 5:06:16 AM
cantilevered steel balconies
Fri, Aug 3, 2007 at 9:25:58 PM
question re: extending walls into roofs
Tue, Feb 10, 2004 at 3:13:38 PM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Page generation time: 4.9495
