Forums >> Revit Building >> Technical Support >> Keynotes
Fri, May 12, 2006 at 5:39:46 PM | Keynotes
Letmethinking
How does this Keynote thing works? We have keynotes "Sheet Specific" and each sheet is numbered starting from 1 thru howmany. How can we use Revit Keynotes in Similar way.
Thu, Dec 7, 2006 at 4:06:45 PM | Keynotes
MrBob
3 Stars: 2 Votes
Did you ever get this worked out?  I am facing this problem right now.  Any info would be appreciated.  Smile
Wed, Dec 12, 2007 at 9:27:59 AM | Keynotes
K8vitali
did anyone ever get info on this? the issue i am having is taht the standard my firm has adopted uses keyntoes the look like the window tags out of the box from Revit- so i am struggling with the way the system notes-   i can make a new family and assign parameters worst case, but when we tag, we dont tag according to Spec sections or text- everything is a number that is referenced along the side of the final sheet in a legend.  i am currently on the prowl for answers and will post back  if i find something useful-
Tue, Jul 7, 2009 at 9:47:02 AM | Keynotes
Bimman
Bimman Avatar
1 Stars: 2 Votes
same problem any on get it figured out?
PWD
Fri, Jul 31, 2009 at 3:24:55 PM | Keynotes
alw7777
I don't know if anyone is still looking for answers but there are a couple things to note:
There is a difference between "sheet notes" and "key notes". Sheet notes are generally used to notate the sheets (whether it be a plan, elev, section, etc). Key notes are generally used to notate details. Our firm's keynotes are connected to a keynote text file which assigns a CSI specific number and description to detail components. I think other firms use generic numbers which connect to a schedule. Keynotes are "linked" to detail components, Sheet notes aren't "linked" to anything specific.
If you are trying to use sheet notes, the best thing to do is create one sheet note for each sheet or series and use the filtering abilities to filter out sheets you don't want.
 I.e. if you have sheet notes for your a02 series (in our case, these are construction plans) that symbol is called A02.00. That symbol is then scheduled using a Note Block which can be put on multiple sheets. Filter out what you do and do not need. This can get complicated, but once the front end work is set up - it's a lot easier. Hope this helps...
Mon, Mar 15, 2010 at 3:17:05 PM | Keynotes
Embeddedif
We are looking to use keynotes for the first time. We were hoping for a keynote linked to the database that isn't necessarily connected to any objects. I.E one we can use on line drawn details or just placed on sheets the same way you can with normal text annotaions. Would it be possible with these 'sheet notes' refered to here? Can't seem to find anything on the subject in the help menu.
Mon, Mar 15, 2010 at 3:34:00 PM | Keynotes
Use the Revit keynote system for everything including drafting views.  You can create an invisible detail component in the family editor, then place it in the drafting view and keynote "user".  One invisible detail and as many keynotes in the view as you need.
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 2.8485
