Forums >> Revit Building >> Technical Support >> Fatel Error Message
Fri, May 12, 2006 at 2:21:53 PM | Fatel Error Message
bolandereric
I create the outside of my building with a generic wall while I am still in the design phase. Once the client has figured out what they wnat on the exterior for finish I change the wall to have the right finish on it. If I have already attatched the wall to a roof componanet and then change the wall to a stacked wall and then try and do anything with the wall revit comes up with a message that says Fatel Error the program will terminate. Does anyone know why? To fix the problem I erase the wall and redraw the wall in and then attatch it to the roof it works just fine.
Sat, May 13, 2006 at 5:18:41 PM | RE: Fatel Error Message
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This shouldn't result in a fatal error, so first ensure you are using the latest build of revit. If you are i recommend filing a support request so this error can be addressed You should simply receive a normal revit error message stating something about stacked walls consisting of multiple walls and all parts of the wall are assuming the same attach command and as such the wall cannot be created. Simply detach the wall first from the roof, then change it to the stacked wall and re-attached it. HTH.
Need Gerneral answers to General questions
Wed, Mar 22, 2017 at 2:05:39 AM
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:33 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:33 AM
Keynotes Error Message
Mon, Jan 24, 2011 at 9:12:17 AM
Page generation time: 0.7127
