Forums >> Revit Building >> Technical Support >> How to edit components?
Thu, Aug 19, 2004 at 1:44:51 PM | How to edit components?
Kevboat
How or can a component object (chair, table, etc.) be edited when there are no editable attributes in the Element or Type Properties windows? I have an object that shows up white when rendered and I'm trying to give it some color and texture.
Thu, Aug 19, 2004 at 5:34:07 PM | RE: How to edit components?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hi, You can add material parameters to most families by opening the family, create new material parameters and them associate them to the geometry by clicking on the elements then setting the material to equal the parameter. Alternatively, you can just assign materials in the family without making them a parameter. However, if the family is already loaded when you reload the family the materials will not update. This all relies on the family not being a DWG import. In which case you can not change the materials in the conventional manner. If you go to settings-->materials-->then check the list. There will most likely be some imported materials. If you change the accurender links to these materials it should update the model materials. But, it will be trial and error on what materials apply to which elements. That should cover everything on materials... Cheers.
how to edit planting components
Fri, Apr 20, 2012 at 1:39:00 AM
Detail components
Fri, Sep 14, 2007 at 9:13:42 AM
cant purge electrical components
Sat, Apr 16, 2016 at 3:33:28 PM
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:06 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
Page generation time: 0.7841
