Forums >> Revit Building >> Technical Support >> How to do parking stall counts in 8.1?
Fri, May 12, 2006 at 6:42:58 AM | How to do parking stall counts in 8.1?
MrCampy
Anyone have any idea of how to set up a schedule to have the counts for each type of stall done automatically as well as having the stalls numbered? I have set up a chart but it seems to do a count per individual space rather than a running total of all spots or even of the types of spots. The spaces are attached to a floor rather than a ramp but numbering and tallying them up is a pain.
Fri, May 12, 2006 at 7:14:42 AM | RE: How to do parking stall counts in 8.1?
reviteer
1 Stars: 1 Votes
I have done several different types. My current method of choice is to not distinguish by type/size of stall, but rather to just make running totals. I do distinguish between areas, so I use the Comments field to give those stalls a particular region name, such as "Main Parking Field." To account for ADA spaces, I use the wheelchair insignia, with an entry into the comments field saying as much. I set up multiple schedules depending on the code requirements for a particular project, something along the lines of 5 spaces per 1000 SF and then another for Total Handicap Parking. Note that all these families are "Parking" families, and if you wanted to categorize by size, just sort them by family/type. Also, to label them (which I rarely do now), you can make a nice little "Tag" for parking, and just use the tag command like you would on a door or window. If you want a Tag, I can post it here for you, its just a circle with a number in it. I find that to be too irritating at large scales, but at finer scales, it works like a champ.
Fri, May 12, 2006 at 7:20:38 AM | RE: How to do parking stall counts in 8.1?
MrCampy
Please post that tag if you could and I will try to set this plan up and let you know later. Thanks again for the help.
Parking Stall & No.
Tue, Jul 12, 2005 at 4:41:07 PM
Parking Tag that numbers parking bays sequentially PLS...
Tue, Dec 6, 2016 at 5:55:48 PM
Curved Parking
Thu, Jun 9, 2011 at 11:04:47 AM
Parametric Stall
Tue, Apr 6, 2010 at 11:17:23 AM
Scheduling multiple parking families
Wed, Sep 7, 2011 at 7:50:18 AM
Page generation time: 0.0361
