Forums >> Revit Building >> Technical Support >> dubble-curved curtainwall
Fri, May 12, 2006 at 6:27:26 AM | dubble-curved curtainwall
jeco
hi! i try to get a standard curtain wall in an dubble-curved surface but it won't work. the dubble-curved solid will accept only basic walls. what can i do?
Fri, May 12, 2006 at 8:45:18 AM | RE: dubble-curved curtainwall
kwebber
I don't know how complex of a wall you are trying to create, but you can create a double curved curtain wall by creating a mass with on face being the double curve you are looking for. then make that face a curtain system. You must create the mass as a solid blend. I hope this helps!
Sat, May 13, 2006 at 5:36:04 PM | RE: dubble-curved curtainwall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Don't use the curtain wall in your wall types, use a curtain system.
Sun, May 14, 2006 at 8:45:08 PM | RE: dubble-curved curtainwall
jeco
worked perfect! thanks!!
curtain wall in solid blend
Wed, May 10, 2006 at 4:15:19 AM
Curtainwall edit profile
Fri, Jun 12, 2020 at 7:48:21 AM
Adding a Single-segment mullion to a curved curtainwall
Sat, Feb 9, 2008 at 8:00:15 AM
Converting curtainwall into wireframe
Wed, Jun 13, 2012 at 2:08:44 PM
12
Near perfect Profile sweeps can't join in custom curved curtainwall family.
Wed, Jan 6, 2016 at 1:05:42 PM
Page generation time: 1.0296
