Forums >> Revit Building >> Technical Support >> Dimension Display in Inches
Thu, May 11, 2006 at 7:34:59 PM | Dimension Display in Inches
Letmethinking
How can I display my Dimensions smaller then 1'-0" in Inches...rather then 0'-5"
Thu, May 11, 2006 at 9:45:46 PM | RE: Dimension Display in Inches
coreed
coreed Avatar
4 Stars: 16 Votes
on the pull-down menu select Settings ==> Annotations ==> Dinensions ==> Linear... From the Type Properties Dialog Box that pops-up Click the button to the right of Units Format under the Text section From the Format Dialog Box that pops-up put a check in the box next to Suppress 0 Feet HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Feb 25, 2008 at 2:16:29 PM | Dimension Display in Inches
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Can you do this for inches too?  So dimensions will read 4'-1/2".  Rather than the default: 4'-0 1/2" ??  Thanks,
Lorne
Denver, CO
Revit Architecture
DIMENSION SETTINGS
Thu, Jun 12, 2008 at 12:54:38 PM
Dimension Inches w Replace text not working
Thu, Feb 27, 2014 at 7:13:14 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
tag display paramenter
Mon, May 16, 2011 at 2:50:11 PM
Revit Reporting Parameter
Tue, Aug 6, 2013 at 10:47:43 PM
Page generation time: 1.6238
