Forums >> Revit Building >> Technical Support >> rotating a horizontal sun shade to a vertical sun shade
Thu, May 11, 2006 at 6:11:19 PM | rotating a horizontal sun shade to a vertical sun shade
nuggy
Just wondering how would I rotate a horizontal sun shade ( I d/l one from the site) so that it becomes a vertical sun shade...not too familiar with Revit but know a bit about families etc- do you somehow use the flip control? If so, how and what needs to be done? Any info much appreciated. Andrew
Fri, May 12, 2006 at 1:14:08 AM | RE: rotating a horizontal sun shade to a vertical sun shade
eldados
eldados Avatar
4.5 Stars: 8 Votes
YOU WILL NEED TO GO INTO THE FAMILY, UNCONTRAIN IT AND ACTUALLY ROTATE IT. YOU WILL ALSO NEED TO RE-DIMENSION AND CONSTRAIN... HAVE A LOOK AT WHAT YOU GOT. GIVE IT A GO AND LET US KNOW (SORRY ABOUT THE CAPS...)
Integrator
KarelCAD
shade diagrams
Tue, Apr 21, 2009 at 8:04:33 PM
Railings as Sun Shade???
Sat, Apr 25, 2009 at 7:59:15 AM
metal shade struture
Mon, Apr 4, 2005 at 7:34:23 PM
Shade view of toposurface
Fri, May 19, 2006 at 9:35:11 AM
Setting Paramtric Rotation Angle for Oval
Tue, Apr 8, 2008 at 5:15:14 PM
Page generation time: 4.0245
