Forums >> Revit Building >> Technical Support >> Tails on detail bubbles
Wed, May 10, 2006 at 1:17:48 PM | Tails on detail bubbles
broshar
How do you modify the tail on a detail bubble? The tail shown on my details is too large on an 1/8" scale elevation, and obscures the element it refers to. I select the detail bubble and find parameters that could be edited, but I cant find the file to edit... Thanks,
Mon, May 15, 2006 at 5:51:44 PM | RE: Tails on detail bubbles
JDahl
Here is the one our company uses... One of the engineers that started us using revit created this to match what we used in Autocad so dont ask me what he did... the beginning of the file name is probably what the standard one in revit is called.
Detail/Section Heads and Tails Not Connecting?
Fri, May 7, 2010 at 8:02:49 AM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
Section and Detail Tails
Sun, Jun 18, 2006 at 9:30:05 PM
Revit 2009 : Section Tails: How to create custom Section Tails
Thu, Jul 17, 2008 at 3:25:05 PM
Section Cut heads and tails automatically toggle on when you adjust crop region
Wed, Oct 10, 2007 at 11:45:19 AM
Page generation time: 0.2985
