29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> spider fitting for point supported glass
1 Posts No Rating |
I am trying to model a curtain wall with a point supporting spider fitting and eventually a steel facade post behind. Should I model half a panel with a quarter fitting attached?
Assuming you have access to the Autodesk Subsciption site, there is a class that was taught at Autodesk University 2005 that has the technique and the spider and panel families created.
If you log-in to the subscription center, click on the AU2005 link, go to the Building Design section of classes and to:
BD41-1 : Advanced AutodeskĀ® RevitĀ® Building Techniques
Download the class handout and datasets. You can also view a recording of the class which is well worth the 3 hours of time it will take.
Tom
GLASS RAILINGS |
Fri, Apr 3, 2009 at 3:22:29 PM
Revit Curtain Wall Spider Connection Issues |
Tue, Sep 9, 2014 at 8:31:13 AM
spider systems |
Wed, Nov 20, 2013 at 7:27:53 AM
Change which fitting family is automatically applied while connecting duct? |
Wed, Jul 22, 2020 at 11:20:15 AM
Sanitary fitting isnt working right |
Wed, Aug 21, 2019 at 11:19:32 PM
