15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Using spit segment when cutting a detail on plan
46 Posts No Rating |
Anybody have the problem when using split segment, when you do it and pull the detail bubble off to the side to where you want it, you click the 2nd point you want it moved to and it will automatically jump a couple inches up or over on the sheet and make the leader to the actual cut way too long? I dont see any apparent reason for this and it seems like it is a glitch. I did an AVI screen capture of this happening, but it came out at like 23 megs for a short 5 second clip so I cant show you what I mean....
roof remove cut segment |
Fri, Jun 1, 2007 at 6:44:44 PM
roof geomerty cutting |
Fri, Jun 1, 2007 at 3:44:48 PM
split segment on detail view |
Tue, Nov 20, 2007 at 12:55:02 PM
RA2008 Plan Region Removes Wall Detail Outside of Region [ 1 2 ] |
Thu, Sep 18, 2008 at 8:19:25 AM
16
Floor Plan - Window Cutting Problem |
Fri, Jan 7, 2011 at 4:16:59 PM
