Forums >> Revit Building >> Technical Support >> Can leaders and dimensions be modified
Wed, May 10, 2006 at 9:11:31 AM | Can leaders and dimensions be modified
JDahl
I want to add a 3rd "dot" or handle to the leader family so I can make all my leaders appear to match from a detail. We always have a straight portion coming from the note, but if I need to angle the leader somewhere else, I cant have the straight part too. I would also like the leaders going to the right on a note with 2 or 3 lines of text to come off the end of the note instead of the end of the first line. With dimensions, is there a way to override the default dimension text?? At times while detailing items have to be exaggerated to show up correctly, but then when dimensioned it needs to be different than what is actually drawn as. Also we use dimensions that dont have the actual length, i.e. a dimension line that reads - 1/2" dia. anchor bolts at 24" o.c. Thanks
Fri, Dec 19, 2008 at 6:55:02 PM | Can leaders and dimensions be modified
AEDIS
I have this same question.  Has anyone found out a way to modify the number of segments on a leader line?
Mon, Dec 22, 2008 at 11:02:52 AM | Can leaders and dimensions be modified
JDahl
No not really... we got an answer back from Autodesk, stating your firm will be added to the list of people wanting this change and it should be added to a future release... since we have gotten two or three new versions...
My work around was and has been using a blank leader that I downloaded from here or possibly augi.com. It is really a pain though especially if you put a bunch of them in and then change the scale of a detail or drawing.
Good Luck
Jeff
Goofy arcs with dimansion leaders
Fri, Feb 22, 2008 at 1:44:32 PM
Modified family not loading into project
Sat, Mar 23, 2019 at 10:32:48 AM
Deleted Dimensions w/ CAD Reload
Tue, Feb 12, 2013 at 2:33:36 PM
Leaders moving_Annoying
Fri, Jan 20, 2012 at 7:37:30 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
Page generation time: 0.9132
