Forums >> Revit Building >> Technical Support >> Bulkhead
Tue, May 9, 2006 at 1:10:51 PM | Bulkhead
arch00
Any suggestion on what command I could use for a drywall bulk head? Gar
Tue, May 9, 2006 at 1:20:47 PM | RE: Bulkhead
TomDorner
4.5 Stars: 25 Votes
I just use walls for bulkheads. I typically constrain there top and bottom to to a level and give them the proper offsets top and bottom. If you want to get more technically correct, create a new walltype that is just for bulkheads and in their type properties set their function to "soffit". Tom
Tue, May 9, 2006 at 1:31:28 PM | RE: Bulkhead
arch00
Thanks again Tom, that was what I was thinking but wanted to see if this was something that was typically used. By the way Tom how long have you been a Revit user? Isee you answer a lot of questions for people. Gar
Tue, May 9, 2006 at 1:37:24 PM | RE: Bulkhead
TomDorner
4.5 Stars: 25 Votes
I've been using Revit for a little over three years now. I'm a lame duck here where I work right now as I gave notice that I accepted a new position at a national A/E firm to implement Revit. I probably won't have the same amount of time in the near future to be as active on this forum. Meantime, ask away! Tom
Tue, May 9, 2006 at 1:40:50 PM | RE: Bulkhead
coreed
coreed Avatar
4 Stars: 16 Votes
that's great news about the new job tom
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 9, 2006 at 2:24:11 PM | RE: Bulkhead
arch00
Congrats Tom, hope you will try to make time to still make a cameo on the forum once in a while. Gar
Mon, May 14, 2007 at 1:33:58 PM | Bulkhead
jmqrsq
5 Stars: 3 Votes
i know this thread is a year old, but i cannot find anywhere else this might be applicable. I understand the whole create wall thing for bulkheads, but what if you wanted to tag it with a height above finished floor? this way wont work will it? and what exactly does the soffit type do to the wall type actually? thanks
Basement Bulkhead Doors
Wed, Jul 12, 2006 at 11:56:00 AM
Angled Bulkhead to a Stair well ceiling
Tue, Nov 16, 2004 at 11:39:30 AM
Joining walls in line based family
Thu, Jun 13, 2013 at 8:50:26 AM
Bulkheads
Tue, Dec 8, 2009 at 3:55:34 PM
Bulkhead
Sun, Jun 17, 2012 at 4:45:09 PM
Page generation time: 0.7391
