Forums >> Community >> Newbies >> ELEVATOR
Tue, May 9, 2006 at 9:52:48 AM | ELEVATOR
vreeves
How do I show the door opening of an elevator on 1st floor infront and on the 2nd floor at the rear?
Tue, May 9, 2006 at 10:06:27 AM | RE: ELEVATOR
coreed
coreed Avatar
4 Stars: 16 Votes
if it is the same elevator, with a door at the front and rear then you could could use a plan region to control the display of each door HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 22, 2010 at 9:35:11 AM | ELEVATOR
sameerahmed786
NEW PARAMETRIC ELEVATOR FROM REVIT CONTENT.COM IS VERY IMPRESSIVE, YOU CAN CREATE ANY CABIN FROM ROUNDED TO SQUARED SHAPES AND HAVE ALL THE ELEVATOR TYPES. THE ALL IN ONE FAMILY HAS A CATALOGUE FILE.....WHICH ALREADY HAS ALLOT OF OTIS PRE SET TYPES. BY FAR THE BEST FAMILY I HAVE SEEN....
ALL THE OTHE FAMILIES I HAVE PURCHASED ARE AMAZING
www.revit-content.com
Tue, Jun 22, 2010 at 10:08:24 AM | ELEVATOR
TomDorner
4.5 Stars: 25 Votes
Elevators by their very nature have two doors for each opening, one for the elevator cab and another for the wall enclosing the shaft.  For the shaft wall you can simply insert a door hosted by the shaft wall.  For the elevator cab, I simply use a symbolic representation of an elevator cab created from AutoCAD lines from Otis or whomever.  No need to pay for such symbols and frankly don't see the real value in having a 3D elevator cab in my model.  As long as the shaft opening is the correct size what does a 3D model of an elevator cab give you?
My 2 cents from an 8 year Revit user and 3 year Autodesk employee.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Jun 22, 2010 at 10:11:09 AM | ELEVATOR
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Internet etiquette rule No. 1.
Please Turn off your CAPS LOCK. It makes your post difficult to read and YOU APPEAR TO BE YELLING AT US.
Fri, Aug 26, 2011 at 8:16:45 AM | ELEVATOR
ElevatorRevit
ElevatorRevit Avatar
4.5 Stars: 2 Votes
You may also download Elevatorarchitect. It helps you on the one hand to choose the correct elevator for your building and imports it into your Revit project, and in the settings you can easily select for each level if you want to have the door opening infront or rather at the rear or both.
The plug-in is free and can be downloaded at http://www.digipara.com/DownloadEARevit.aspx
Tue, Mar 20, 2018 at 6:51:32 AM | ELEVATOR
JessicaMadison
The lift on first and second floor separate entryways opening is the best plan, meanwhile, you'll, in the long run, get to someplace the way for the lift is individual locations on various floors.
need help on elevator...
Fri, May 25, 2018 at 4:23:17 AM
New Elevator Family
Wed, Sep 13, 2017 at 6:42:18 AM
elevator BIM model
Fri, Sep 14, 2012 at 4:04:11 AM
Fire door in front of elevator door
Thu, Feb 3, 2011 at 1:37:28 PM
Elevator / Maint. Pit - Revit Architecture 9
Mon, Mar 30, 2009 at 2:20:14 PM
Page generation time: 0.0350
