Forums >> Revit Building >> Technical Support >> Glass Panel Doors with Mullions
Tue, May 9, 2006 at 9:28:05 AM | Glass Panel Doors with Mullions
3ddraft
3 Stars: 1 Votes
I am trying to create a family of doors that include mullions and have been working on a 9 lite door. Every time I try to use the method of defining mullion patterns that is given in the window family tutorial, I keep getting an error message. It says that the base sketch in invalid. This occurs after I have created the new paramater name "Mullion Offset" and then try to set it to the distance, say 1'-2". I did set up refrence lines on the edges of the window panel in the door. Doing that eliminated the error. However, when I define a distance for the offset, it moves the line I'm trying to refrence the mullions from. Not the mullion itself.
Tue, May 9, 2006 at 10:35:20 AM | RE: Glass Panel Doors with Mullions
jron
I think that the extrusion that you are using for the mullion needs to be locked to the ref. line.
Tue, May 9, 2006 at 10:51:56 AM | RE: Glass Panel Doors with Mullions
3ddraft
3 Stars: 1 Votes
Would that still be the problem if I'm not creating an extrusion at the time and only creating the center reference lines for the mullions? Sorry if I'm asking a redundant questions but I'm just starting so I want to make sure I'm following correctly. Thanks
Tue, May 9, 2006 at 11:19:00 AM | RE: Glass Panel Doors with Mullions
jron
Yes, that mullion needs to be locked to the Reference for it to move.
Panel tags for glass doors with frame in curtain walls
Thu, May 1, 2014 at 7:51:48 AM
Looking for Large 3, 4 & 5 Panel Exterior Glass Sliding Doors. (Florida Style)
Fri, Feb 16, 2007 at 12:39:11 PM
External Glass Curtain Panel Problem
Tue, Aug 12, 2014 at 8:05:34 AM
Problem selecting glass using tab key
Thu, Mar 21, 2019 at 1:17:37 PM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Page generation time: 1.8681
