14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Open GL & Graphics Card
I have never been able to use Open GL hardware accelartion setting because my graphics card purports to support it but revit has many problems when using that setting, as a revit dialog window warns may happen when you select it... (settings->options->graphics)
My card is an NVIDIA Quadro FX 1400, I installed the latest "Autocad certified" driver.
[1] Can other users tell me what cards they have and if they are working well with OpenGL?
[2] does having OpenGL on fix the problem I have a lengthy forced refreshes when shadows are on?
[3] other benefits to OpenGL?
Thanks
I have the same card.
you can spend $$$$ on a card but you will see no benefit in Revit just yet. the problem is that the card manufactures don't get the info they need from revit in order for openGL to work!
this might take a while...
pissed me off for a while there
lumion graphics card use |
Tue, Dec 2, 2014 at 2:03:22 AM
Graphics card causing crash |
Tue, May 6, 2014 at 12:31:00 PM
7600 GT GRAPHICS CARD COLOUR PROB'S IN REVIT |
Wed, May 7, 2008 at 11:34:38 PM
Revit graphics card? |
Thu, Feb 20, 2014 at 12:47:10 PM
Graphics Card |
Mon, Aug 8, 2011 at 2:33:04 PM
