Forums >> Revit Building >> Technical Support >> Rendering Ground Planes showing up when i dont want them to
Tue, May 9, 2006 at 7:22:30 AM | Rendering Ground Planes showing up when i dont want them to
twinvalley
4.5 Stars: 3 Votes
Hi, When i render my house with uneven elevation, it renders it with a gray ground plane across the entire ground level. If i turn on the ground plane it shows up with the selected texture. So i went back and just unchecked it and it still shows up with a grass ground plane. It seems to do this on every file i start, never used to do it either. Any Ideas as to what the problem or solution may be.
Tue, May 9, 2006 at 7:26:33 AM | RE: Rendering Ground Planes showing up when i dont want them to
iqlayser
4 Stars: 1 Votes
You have to make a pad around the basement walls. the pad-tool is in the site-menu
Tue, May 9, 2006 at 7:27:03 AM | RE: Rendering Ground Planes showing up when i dont want them to
iqlayser
4 Stars: 1 Votes
just clikk on pad and pick walls
Tue, May 9, 2006 at 7:44:32 AM | RE: Rendering Ground Planes showing up when i dont want them to
twinvalley
4.5 Stars: 3 Votes
I tried puttin a thin pad around the basement from floor 1 to the site, and from the footing to the site, i tried puttin a pad inside the basement and its still adding the ground plane and its not even checked in the render settings. I also couldn't pick walls on any view to do the pad so i used lines Post edited on 2006-05-09 07:46:06
Tue, May 9, 2006 at 8:11:01 AM | RE: Rendering Ground Planes showing up when i dont want them to
iqlayser
4 Stars: 1 Votes
then i really don`t know, sorry.
Wed, May 10, 2006 at 7:14:43 AM | RE: Rendering Ground Planes showing up when i dont want them to
twinvalley
4.5 Stars: 3 Votes
Anyone else have any idea what might be going on? Thanks
Problem Showing Ground on Rendering
Fri, Feb 8, 2008 at 8:15:18 AM
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:08 PM
Wed, Oct 4, 2006 at 1:00:19 PM
Ground Plane in Rendering
Tue, Feb 22, 2005 at 2:25:54 PM
ground plane rendering
Thu, Aug 16, 2012 at 11:54:38 AM
Page generation time: 0.4102
