Forums >> Revit Building >> Technical Support >> Bolt Holes in Columns
Tue, May 9, 2006 at 3:58:19 AM | Bolt Holes in Columns
zubbo
I have several UC Columns in my building, I have attached plates to my horizontal beams which were done as a in place family, is there a way to create holes in my column flanges to match my plates.
Tue, May 9, 2006 at 2:55:31 PM | RE: Bolt Holes in Columns
quiller
quiller Avatar
2.5 Stars: 3 Votes
edit the column family and add the holes, then re-load the family into your project
Tue, May 9, 2006 at 2:56:28 PM | RE: Bolt Holes in Columns
gregmeurer
4.5 Stars: 9 Votes
thats the way i would do it too.
Tue, May 9, 2006 at 3:51:57 PM | RE: Bolt Holes in Columns
zubbo
I thought that would be the only way. Thank-you for your time to respond.
Sun, Mar 23, 2008 at 8:52:36 AM | Bolt Holes in Columns
boydj
What if it was not create in place.
I am trying to do almost the exact same thing.  But I have created individual families, and brought them together.  Is there a way I can bring all the pieces together and then punch one hole (void) through the entire thing.  I cnt seem to find a way to make it work.
I also want to call out each element seperately.  I need to create shop drawings for steel fabrication.
Can't dimension to center of a circle? NewtoRevit
Thu, Jan 8, 2015 at 6:43:27 AM
u-bolt creating_newbie revit modeler
Mon, Jun 18, 2018 at 10:53:55 AM
Cut holes in walls?
Thu, Jun 2, 2011 at 10:54:59 AM
Adaptive rectangular pattern with bubbly holes
Thu, Sep 12, 2013 at 6:31:28 AM
Dimensions to baseplate bolts
Mon, Jul 10, 2023 at 3:24:27 AM
Page generation time: 1.5701
