Forums >> Revit Building >> Technical Support >> Mansard Roof?
Mon, Aug 16, 2004 at 2:05:37 PM | Mansard Roof?
jrwilliams
How do you go about constructing a Mansard roof in Revit?
Mon, Aug 16, 2004 at 5:11:40 PM | RE: Mansard Roof?
skisouth
5 Stars: 3 Votes
Create a level where you would want the mansard to stop (CAll it Roof cutoff - whatever). Create a normal roof with vertical slope you require for the mansard on the level below this new level where you want the mansard's height to stop. Create the roof (which will be a VERY tall gable or hip roof), then select the new roof then under properties select cut off level option - and select the level you created (Roof cut off level). The gable or hip now stops at this level, effectively yielding a mansard. Now create a second roof at the cutoff level to complete the roof. Join the two roofs...
Mon, Nov 26, 2018 at 2:45:22 AM | Mansard Roof?
daavidsall
here is an much better way
https://www.youtube.com/watch?v=Vr31pkDRyjw&t=28s
Problem with Mansard Roof
Wed, Mar 5, 2008 at 9:06:14 AM
curved mansard roof
Wed, Feb 18, 2015 at 3:56:01 PM
Mansard roof madness
Sat, Apr 1, 2017 at 4:54:07 AM
mansard roof with cutoff level not working...
Thu, Sep 15, 2011 at 9:13:03 AM
Mansard roof!!! please help me!
Sun, Dec 2, 2007 at 7:04:25 PM
Page generation time: 3.0034
