Forums >> Community >> The Studio >> Foundation Plan and Dimensions
Fri, May 5, 2006 at 1:13:42 PM | Foundation Plan and Dimensions
Letmethinking
How Do I make my foundation Plan. I just wanna show footing in dashed, and dimension from a certian point to the other, revit won't let me just pick a line or point. Thanks in advance for help guys
Fri, May 5, 2006 at 1:46:37 PM | RE: Foundation Plan and Dimensions
bolandereric
You can change the footing lines to dashed by going in to the visibility graphics and change the line style on structrual foundations. It is called an override.
Mon, May 8, 2006 at 4:00:14 PM | RE: Foundation Plan and Dimensions
miannucci
do you know how to center the footing under the wall core instead of the entire wall?
Mon, May 8, 2006 at 4:06:29 PM | RE: Foundation Plan and Dimensions
bolandereric
On the Parameter you can set the distiance from the side of the wall to the edge of the footing. Set the toe length diffrent from the Heel Length. So that the footing is centered on the core of the wall.
Thu, May 11, 2006 at 6:37:47 PM | RE:
Letmethinking
Quoting miannucci - 2006-05-08 16:00:14
"do you know how to center the footing under the wall core instead of the entire wall?"
Well not really. Is the Foundation tool same as wall tool but with different height and stuff?
Slab in foundation plan
Wed, Dec 21, 2005 at 5:10:28 PM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
Foundation Plan
Tue, Sep 7, 2010 at 4:47:03 PM
Foundation plan/level view (R2013)
Wed, Nov 14, 2012 at 12:19:31 PM
Foundation plan view depths
Sat, Jun 17, 2023 at 1:34:14 PM
Page generation time: 0.4091
