Forums >> Revit Building >> Technical Support >> line weight
Fri, May 5, 2006 at 11:03:18 AM | line weight
NiDo
we have some problems of the line weight of multi-layer walls, the outer lines are thick and the inner lines are fine (like the definition in the object styles) is it possible to change or define the thickness of the lines for one layer in a multi-layer wall? please look also at the picture ....
Mon, May 8, 2006 at 4:03:53 AM | RE: line weight
eldados
eldados Avatar
4.5 Stars: 8 Votes
Yes, under you visibility/graphics tick "cut line style" under "override host layer" click edit and assign line weight to different wall layers
Integrator
KarelCAD
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:55 PM
Column Grid Line Weight
Sun, Aug 13, 2017 at 3:05:53 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
Page generation time: 1.4396
